[CH 2.1.6g] Forum Clock - Hodiny
Forum Clock
Nainstaloval jsem i na toto fórum mód Forum Clock, kterej jak už název napovídá, přidá na fórum hodiny.
Je to velmi jednoduchej mód na instalaci, protože se víceméně upravuje jenom jeden soubor templátů (a nahrává jeden soubor do fóra) a navíc si můžete zvolit, kam hodiny chcete umístit.
Kód: Vybrat vše
## MOD Title: Forum Clock
## MOD Author: Drumstix42 < Drumstix42@aol.com > (Mark Schlitz) http://www.advancedmod.com
## MOD Description: This MOD will add a simple Flash clock to your
##                  forums. Tested on 2.0.5 and 2.0.6. Should work
##                  on previous version as well.
## MOD Version: 1.0.2
## Installation Level: Easy
## Installation Time: 2-5 Minutes
## Files To Edit: index_body.tpl
## Included Files: Clock.swf
## For Security Purposes, Please Check: http://www.phpbb.com/mods/ for the
## latest version of this MOD. Downloading this MOD from other sites could cause malicious code
## to enter into your phpBB Forum. As such, phpBB will not offer support for MOD's not offered
## in our MOD-Database, located at: http://www.phpbb.com/mods/
## Author Notes:
##	 This is a very simple MOD to add a Flash clock to the
##       bottom of your forums in no time. It uses the person's
##       computer's clock time, so no configuration is
##       neccessary. It works on 2.0.5 and 2.0.6. Should work
##       fine on just about any version since it's just HTML
##       code overall. Also, will work with most templates,
##       you just need to know the classes for borders and
##       backgrounds if wanted.
##       For a preview, check out my forums at:
##       http://www.advancedmod.com/forums/
##       And scroll down to the bottom.
##       Enjoy!
## MOD History:
##   2003-08-11 - Version 1.0.0
##      - Clock working fine. No changes needed.
##   2003-09-13 - Version 1.0.1
##      - Updated to use the $lang system, adding 2 new steps.
##   2003-09-14 - Version 1.0.2
##      - Updated step one adding 'copy ' to the begining, correcting
##        the previous invalid syntax.
## Before Adding This MOD To Your Forum, You Should Back Up All Files Related To This MOD
Mód můžete stáhnout na phpBB.com fóru
Další hodiny můžete najít tady: http://www.cyber-junkie.com/fun/clocks/
Hodiny pro tmavý styly:
Kód: Vybrat vše
#-----[ OTEVŘÍT ]------------------------------------------
templates/subSilver/index_body.tpl
# nebo soubor, kde hodiny máte nainstalovaný
#-----[ NAJÍT ]------------------------------------------
<div align="center"><embed width="170" height="150" src="./Clock.swf">
    </div>
#-----[ VYMĚNIT ZA TOHLE ]------------------------------------------
<OBJECT classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"
 codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,0,0"
 WIDTH="170" HEIGHT="150" id="clock" ALIGN="">
 <PARAM NAME=movie VALUE="./Clock.swf">
 <PARAM NAME=quality VALUE=high>
 <PARAM NAME=bgcolor VALUE=#000000>
 <PARAM NAME=FlashVars VALUE="textColor=0xFF0000&showSeconds=1">
 <EMBED src="./Clock.swf" quality=high bgcolor=#000000  WIDTH="170" HEIGHT="150" NAME="clock" ALIGN=""
    TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/go/getflashplayer"
    FlashVars="textColor=0xFF0000&showSeconds=1"></EMBED>
</OBJECT>
Pokud vám barva nesedí tak ji změníte na této lince:
Kód: Vybrat vše
#000000 - černá
#FFFFFFF - bílá
Hodiny v headeru (jako na tomto fóru):
Neinstalujte do index_body_tpl nebo si tam kód smažte
Kód: Vybrat vše
templates/subSilver/overall_header.tpl
# pár řádků před koncem souboru
{L_LOGIN_LOGOUT}</a>& </span></td>
               </tr>
            </table></td>
#-----[ VLOŽIT ZA ]------------------------------------------
         <!-- Clock Code: Start -->
         <td>
         <table align="center" cellpadding="3" cellspacing="1" border="0"  >
           <tr>
            <td align="center" valign="middle">
             </div>
            </td>
           </tr>
         </table>
         </td>
      <!-- Clock Code: End -->
Hodiny lze dát i na jiný místa - do bloku na portálu, dolů na index fóra do boxu "kdo je přítomen" atd.
