Pár skrýnšotů ze seznamu uživatelů a z profilu uživatele:
## MOD Title: Last Visited (Truncated)
## MOD Author: imrich < forward_imrich@comcast.net > (Rich) N/A
## MOD Description: Adds the date a person last visited your forum to their
## profile and the members list along with the ability to order search
## results by the date they last visited.
## Croped to work with CH by Allstar.
## MOD Version: 1.1.1-CH
## Installation Level: Easy
## Installation Time: 15 minutes
## Files To Edit:groupcp.php,
## memberlist.php,
## includes/usercp_viewprofile.php,
## includes/page_header.php,
## language/lang_english/lang_main.php,
## templates/subSilver/memberlist_body.tpl,
## templates/subSilver/profile_view_body.tpl,
## Included Files: N/A
## Author Notes: Allstar; I found this mod and couldn't get all of it working
## on CH 2.1.4x so trimed it down until it did work and luckily ended up with
## the profile and memberlist bits working.
## MOD History:
## 2006-04-28 - Version 1.1.1-CH
## Cropped for use on CH 2.1.4 & CH 2.1.6 by Allstar
## 2005-08.29 - Version 1.1.1
## Fixed cosmetic things such as using the INCREMENT function instead of using IN-LINE REPLACE which kept mod from being validated by the Mod-Team. No functional differences from 1.1.0.
## 2005-08.08 - Version 1.1.0
## Changes to show last visit in usergroups. Inspired by the posting made by mechagrover, used his code as a base and added a bit more to make it work.
## 2005-04.03 - Version 1.0.8
## Changed to use session data, prelim testing work by by danko (thanks!). This will be a more accurate time of last visit as it takes session_time into account instead of last_visited as last_visted can be old if user checks 'alway stay logged in'.
## 2004-11.25 - Version 1.0.7
## Had error in FIND, misplaced comment delimiter
## 2004-11.25 - Version 1.0.6
## Had error in INLINE ADD, fixed syntax
## 2004-11-25 - Version 1.0.5
## Changed to also display last visit date when viewing posts.
## Updated changes to lang_main.php, additional changes to viewtopic.php and viewtopic_body.tpl
## 2004-11-23 - Version 1.0.4
## Removed single quotes around sql field.
## 2004-11-22 - Version 1.0.3
## Fixed catBottom length (cosmetic issue).
## 2004-11-20 - Version 1.0.2
## Fixed a couple of out of place comment delimiters.
## 2004-11-17 - Version 1.0.1
## Changed REPLACE to INLINE directives.
## 2004-11-09 - Version 1.0.0
## - First Stable release. Version 1.0.0 of a MOD is always it's first stable release.
## Before Adding This MOD To Your Forum, You Should Back Up All Files Related To This MOD
############################################################## V instalaci je malinká chybička:
#-----[ Najít ]------------------------------------------
//-- mod : Last Visited --------------------------------------------------------
'L_VISITED => $lang['Visited'],
//-- fin mod : Last Visited ----------------------------------------------------
#-----[ Nahradit tímto ]------------------------------------------
'L_VISITED' => $lang['Visited'],
#Code: Select all
#-----[ Otevřít ]------------------------------------------
language/lang_english/lang_czech.php
$lang['Sort_Joined']
#-----[ Za to vložit ]------------------------------------------
$lang['Visited'] = 'Poslední návštěva';
$lang['Sort_Visited'] = 'Datum poslední návštěvy';
