[CH 2.1.6h ] CH IM Portal 1.0.8a
Reactions:
CH IMPortal 1.0.8a
Podařilo se mi nainstalovat CH IMPortal, což je vlastně IM portál upravenej pro CH Mod.
Umožní vložit na stránku bloky, do kterých se automaticky posílají příspěvky atd. z fóra.
Mód se dá stáhnout na stránkách CHMods Demoboard.
Češtinu můžete najít tady.
## MOD Title: CH IMPortal
## MOD Author: Craterz < n/a > (n/a) http://www.craterz.com/
## MOD Updated by: Haynes <haynes@chmods.de (N/A) http://chmods.de
## MOD Description: This MOD is a CH 2.1.6h adapted version of IMPortal.
##	phpBB IMPortal by: masterdavid
##	< webmaster@integramod.com > (Ronald John David) http://www.integramod.com/
## MOD Version: 1.0.8a
## Installation Level: Easy
## Installation Time: 25 minutes
## Files To Edit: admin/index.php
##                includes/class_config.php
##                includes/class_stats_online.php
##		  includes/im_portal/class_im_portal.php
##                login.php
##                templates/ptifo/admin/index_navigate.tpl
##                templates/ptifo/overall_footer.tpl
##                templates/ptifo/overall_header.tpl
##                templates/ptifo/ptifo.cfg
##                templates/ptifo/ptifo.css
##                templates/subSilver/admin/index_navigate.tpl
##                templates/subSilver/overall_footer.tpl
##                templates/subSilver/overall_header.tpl
##                templates/subSilver/subSilver.cfg
##                templates/subSilver/subSilver.css
## Included Files: root/*.*
## Author Notes:
##	Based on/with IMPortal 1.2.0 EMC Beta by masterdavid
##	Requires CH 2.1.6e
##	Always backup your files and database prior to installing any MOD.
##	You DO NOT need the original IMPortal MOD, this includes everything you need.
##	Be sure to visit the caches management in the ACP and 'Regen' the Lang cache when complete.
##	This following is shamelessly borrowed from Smartor's ezPortal installation instructions.
##	HOW TO MAKE YOUR WEBSITE OPEN TO FILE portal.php INSTEAD OF index.php ?
##	Do NOT do this until this MOD is successfully installed!
##	You can use one of the following methods! Lots of luck!
##	o Method 1: (for Apache server)
##	      Create/modify file .htaccess in phpBB root directory add/edit this line:
##	         DirectoryIndex index.html index.htm portal.php index.php
##	o Method 2: {use META tag - if you cannot apply the 1st method)
##	      Create file index.html in phpBB root directory (without #)
##	         <html>
##	         <head>
##	         <title>Redirecting...</title>
##	         <meta http-equiv="refresh" content="0;url=portal.php">
##	         </head>
##	         <body>
##	         </body>
##	         </html>
##	      If your phpBB was placed in a subdirectory to the webroot, like: http://www.something.com/forum you could create index.html in the webroot and modify the line 4 to <meta http-equiv="refresh" content="0;url=forum/portal.php">
##	o Method 3: I think maybe you can find out method 3 yourself ;) like JavaScript, etc.
## MOD History:
## 2008-08-26 - Version 1.0.8a
##	-fixed several bugs and missing lang keys
##	-moved towards the CH plugin system
## 2007-10-12 - Version 1.0.8
##      -Updated for CH 2.1.6e compliance
##      -Added ability to control scroll within Recent Topic block
##      -Removed number of posts (x) unread from User Block, cannot determine number
##          on all pages where User Block may be shown (if set in Global Header)
##          May return in future version, but currently is unstable.
## 2006-07-30 - Version 1.0.7
##      -Changed a few things for forum and user blocks, for better/easier tpl editing
##         fetchposts.php
##         blocks/blocks_imp_forum.php
##         blocks/blocks_imp_user_block.php
##         language/lang_english/lang_extend_CH_IMPortal.php
##         templates/ptifo/blocks/forum_block.tpl
##         templates/ptifo/blocks/user_block_block.tpl
##         templates/subSilver/blocks/forum_block.tpl
##         templates/subSilver/blocks/user_block_block.tpl
##      -Redifined a CH language variable for better wording
##      -NOTE: To update, just upload and replace the following files:
## 2006-07-30 - Version 1.0.6
##      -Fixed an issue with group names not properly showing up in ACP pages
##         admin/admin_portal_blocks.php
##         admin/admin_portal_layout.php
## 2006-07-30 - Version 1.0.5
##      -Fixed a javascript error on portal/home page
##      -Fixed a javascript error on all other pages
## 2006-09-03 - Version 1.0.4
##      -Fixed a number of language vars not being filled properly.
##         instead of entire site name.
##         There are no db changes (except one... it's minor and not needed to update).
##         If you've modded the files, make use of WinMerge or some such.
##      -Fixed a few other minor HTML coding issues.
##      -Fixed an issue with the statistics block not showing up after install.
##      -Added a language var so that on Nav block it only shows 'Forum Index'
##      -NOTE: To update, just remove the old files from your site and upload new ones.
## 2006-07-30 - Version 1.0.3
##      -Moved db_update.php to root folder.
##      -Changed Recent Topic block start scroll delay time to 5 seconds.
## 2006-07-30 - Version 1.0.2
##      -Fixed a couple things causing easyMOD to fail.
##      -Added note to regen lang cache.
## 2006-07-10 - Version 1.0.1
##      -Fixed a SQL issue in db_update.php and sql.txt
##      -Fixed a confusing point in installation instructions (this).
## 2006-07-04 - Version 1.0.0
##      -Released to Registered users at my board.
## 2006-07-02 - Version 0.0.4
##      -Added template instructions for ptifo.
##      -Added a missed instruction.
## 2006-06-30 - Version 0.0.3
##      -Fixed the major problem.
##      -Fixed several minor issues with titles and such not displaying.
## 2006-06-29 - Version 0.0.2
##      -Made most necessary changes.
##      -Completely rewrote installation instructions (this).
##      -Renamed SQL inserted tables for better organization.
##      -Created an semi-automated SQL installer.
##      -Navigation block is now truely global.
##      -Includes ACP set Navigation icon.
##      -Rewrote several/many files to make use of CH aspects.
##      -Rewrote scrolling mechanism of Recent Topics block.
##      -Scrolling is now XHTML compliant.
##      -Fixed when recent topic is by a Guest.
##      -Fixed many (X)HTML compliance issues.
##      -Still tracking one major problem.
## 2006-06-27 - Version 0.0.1
##      -Began developing adaption.
Pokud chcete udělat stránku portal.php jako výchozí, tak máte několik možností:
1. Pro Apache servery - Vytvořte/změňte soubor .htaccess ve vašem fóru tak, že do něho vložíte nebo upravíte tento řádek:
2. Vytvořte soubor index.html, který vložíte do vašeho kořenového adresáře fóra a do něj tohle:
<html>
	         <head>
	         </head>
	         <body>
	         </body>
	         </html>
Jestliže je vaše fórum v nějakém podadresáři (např: http://www.cokoliv.com/forum), tak vložte index.html do hlavního adresáře webu a upravte 4 řádek takto:
Reactions:
Úprava bloku navigace
Do Navigačního bloku IM Portálu není moc složitý přidat další odkazy např.: na Sudoku nebo Downloady atd. Stačí otevřít:
templates/váš_vzhled/blocks/navigation_block.tpl
a najít tam tuto část kódu:
			<tr valign="middle">
				<td align="center" valign="middle" width="11">{NAVBLK_ICON}</td>
				<td align="left"><span class="gensmall"><a href="{U_PORTAL}" class="gensmall" title="{L_PORTAL}">{L_PORTAL}</a></span></td>
			</tr>
kterou zkopírujete na místo, kde chcete mít odkaz. Pak jenom změňte "PORTAL" na "SUDOKU" nebo "DOWNLOAD", pokud máte módy nainstalované nebo změňte
na
<a href="http://www.adresa_na_kterou_chcete_odkázat"
Reactions:
Nová verze IM Portálu je k mání na nových stránkách - odkaz najdete v prvním příspěvku.
