BBCode Buttons Organizer
Mody nainstalované na tomto fóru na verzi CH 2.1.6
Mod umožňuje snažší (automatické) zarovnání BBKódů.
Mod můžete najít zde, ale vyhledem k tomu, že jsem v něm změnil kvůli snažší instalaci na CH 2.1.6 1 řádek, tak přidávám i instalační soubor.
## EasyMod Compliant
## MOD Title:    BBCode Buttons Organizer
## MOD Author:   Nuttzy < nospam@blizzhackers.com > (n/a) http://www.spellingcow.com
## MOD Author, Secondary: wGEric < eric@best-dev.com > (Eric Faerber) http://mods.best-dev.com
## MOD CH 2.1.4 rewrite: Cr@ter$ (n/a) (n/a) http://www.craterz.com/
## MOD Description:  Allows for neater display of additional quick BBCode buttons.
## MOD Version:  1.4.0a-CH
## Installation Level:  EASY
## Installation Time:   2 minutes
## Files To Edit:       includes/bbcode.php
##                      templates/subSilver/posting_bbcode.tpl
##                      templates/subSilver/posting_body.tpl
## Included Files:      n/a
## For Security Purposes, Please Check: http://www.phpbb.com/mods/ for the
## latest version of this MOD. Downloading this MOD from other sites could cause malicious code
## to enter into your phpBB Forum. As such, phpBB will not offer support for MOD's not offered
## in our MOD-Database, located at: http://www.phpbb.com/mods/
## Author Notes:
##     + requires Multi BBCode MOD 1.4.0c or later
##      http://www.craterz.com/viewtopic.php?t=229
##       + Works with CH 2.1.4, and probably 2.1.x
##     + Works with phpBB 2.0.2 thru 2.0.18
## MOD History:
##      2005-11-19
##      + Rewrote MOD for CH 2.1.4 compliance
##    2005-02-24
##     + Fixed a bug with the helpline
##    2004-10-16
##     + Updated to work with Multi BBCode 1.4.0
##    2003-09-25 - Version 1.2.1
##         + improved MOD Template compliance
##    2003-08-15 - Version 1.2.0
##         + updated to work with Multi BBCode 1.2.0
##    2003-02-04 - Version 1.0.1
##         + updated for 2.0.4
##         + no code changes required, just updated the header info
##    2002-08-31 - Version 1.0.0
##         + initial release
## Before Adding This MOD To Your Forum, You Should Back Up All Files Related To This MOD
# IMPORTANT: you MUST first install the Multi BBCode Mod v1.4.0 available
#            at http://www.phpbb.com/mods/
#-----[ OPEN ]---------------------------------
includes/bbcode.php
#-----[ FIND ]---------------------------------
for ($i=1; $i<count($EMBB_values); $i++)
#-----[ BEFORE, ADD ]---------------------------------
//-- mod : BBCode Buttons ------------------------------------------------------
//-- delete
//-- fin mod : Multi BBCode ----------------------------------------------------
//-- add
$max_rows = ((count($EMBB_values)-1)/9) ;
$max_rows = ($max_rows*9 == count($EMBB_values)) ? $max_rows : $max_rows+1 ;
$code_count = 1 ;
for ($i=1; $i<=$max_rows; $i++)
   $template->assign_block_vars('XBBcode', array(
      'ROW_ID' => $i)
   for ($element=0; $element<9; $element++)
      $val = ($code_count*2)+16 ;
      if ( $code_count < count($EMBB_values))
         $help_lang = ( !empty($lang['bbcode_help'][(strtolower($EMBB_values[$code_count]))]) ) ? $lang['bbcode_help'][(strtolower($EMBB_values
[$code_count]))] : $lang['bbcode_help'][$EMBB_values[$code_count]];
         $template->assign_block_vars('XBBcode.BB', array(
            'KEY' => $hotkeys[$code_count],
            'NAME' => "addbbcode$val",
            'HELP' => sprintf($help_lang, $hotkeys[$code_count]),
            'WIDTH' => $EMBB_widths[$code_count],
            'VALUE' => $EMBB_values[$code_count],
            'STYLE' => "bbstyle($val)")
      $code_count++ ;
//-- fin : BBCode Buttons ------------------------------------------------------
<!-- BEGIN MultiBB -->
{MultiBB.VALUE}_help = "{MultiBB.HELP}";
<!-- END MultiBB -->
#-----[ REPLACE WITH ]---------------------------------
<!-- BEGIN XBBcode -->
<!-- BEGIN BB -->
{XBBcode.BB.VALUE}_help = "{XBBcode.BB.HELP}";
<!-- END BB -->
<!-- END XBBcode -->
        </tr>
#-----[ AFTER, ADD ]---------------------------------
        <tr align="center" valign="middle">
         <!-- BEGIN BB -->
         <td><span class="genmed">
           <input type="button" class="button" accesskey="{XBBcode.BB.KEY}" name="{XBBcode.BB.NAME}" value="{XBBcode.BB.VALUE}" style="width:
{XBBcode.BB.WIDTH}px" onClick="{XBBcode.BB.STYLE}" onMouseOver="helpline('{XBBcode.BB.VALUE}')" />
           </span></td>
         <!-- END BB -->
        </tr>
#-----[ SAVE/CLOSE ALL FILES ]---------------------------------
# EoM
